Grading
  • Final exam (50%)
  • Programming assignments (50%)
    • Penalty for late and no submissions. Details are given below.
  • Bonus points for class participation
Assignment grading policy
  1. The maximum points for each assignment is 5.
  2. Late submissions also receive a penalty of 0.1 points per day. The late penalty is capped at -5 points.
  3. Not submitting an assignment will result in a penalty of 5 points.
  4. Each assignment will consist of several test cases, with points for each one of them, based on their difficulty level.
  5. A minimum number of test cases should be correct to get points for an assignment.
