One paper accepted at NIPS’14 on multi-armed bandit on graphs
We have presented novel results on how to exploit the structure of the arm set in multi-armed bandit. In particular, we consider the case where by pulling one action additional information is transferred from its neighbors. We show improve regret bounds in this setting.
Efficient Learning by Implicit Exploration in Bandit Problems with Side Observations (Tomáš Kocák, Gergely Neu, Michal Valko, Rémi Munos)
We consider online learning problems under a partial observability model capturing situations where the information conveyed to the learner is between full information and bandit feedback. In the simplest variant, we assume that in addition to its own loss, the learner also gets to observe losses of some other actions. The revealed losses depend on the learner’s action and a directed observation system chosen by the environment. For this setting, we propose the first algorithm that enjoys near-optimal regret guarantees without having to know the observation system before selecting its actions. Along similar lines, we also define a new partial information setting that models online combinatorial optimization problems where the feedback received by the learner is between semi-bandit and full feedback. As the predictions of our first algorithm cannot be always computed efficiently in this setting, we propose another algorithm with similar properties and with the benefit of always being computationally efficient, at the price of a slightly more complicated tuning mechanism. Both algorithms rely on a novel exploration strategy called implicit exploration, which is shown to be more efficient both computationally and information-theoretically than previously studied exploration strategies for the problem.
