Octobre 16 Deployment, adding sensors
Our first external temperature+humidity sensors are alive! Until now, the temperature was measured using the board’s internal temperature sensors. And while those temperature sensors are well calibrated, the measurements were not exploitable as the motes are located into water-tight boxes above the orchard, which tend to “heat up” when in…
