As every JAR file is a library you can use PLASMA Lab as an Application Programming Interface (API). For now you can take a look at our simplified Javadoc to see how you could use Plasma Lab.
You can also use your own simulator and requirement checker in Plasma Lab by writing a plugin. In order to do this you just have to implement a small interface.
Important!
Here is a list of the plugins currently available in PLASMA Lab.
