New search again optimised!
The new search in Shanoir-NG is now even more user-friendly! Now to filter through millions of datasets using either the easy or expert mode, the result table can be modified in real-time: check columns you need or not, and even set with a background preview the desired pixel size for each column to fit your needs and the size of your display!
