A documentation for the components can be found at this address: https://softrobotscomponents.readthedocs.io
Developers’ guidelines |
In the following, you will find the general methods used, with appropriate parametrization, for the implementation of the various components. Some documentation on subjects related to the plugin is also provided in the miscellaneous section.
Methods |
Miscellaneous |
