In 2017 Inria offers 1 Post-Doc fellowship in the framework of EPFL-Inria International Lab. Dealine for application is April 15th, 2017.
The collaborative nature of the work should be clearly stated. Projects with an already identified candidate will have a higher probability of being selected. Although the research area is open, the theme of the EPFL/INRIA joint lab is “Systems for the Future Internet”. Projects falling within this theme (very broadly speaking) will be favored.
Candidates interested in the projects currently supported are welcome to submit their application to a post-doctoral fellowship. Candidates are strongly encouraged to get in touch with the PIs of these projects, either at EPFL, or at Inria.
Applications will include:
- The summary sheet to be downloaded here;
- Detailed CV including a description of the PhD work and a list of publications – and 2 selected publications;
- Research program, work plan and planned visits during the postdoc, and planned duration of the post-doc (12 or 16 months) and the desired starting date (default start date is November 1st, 2017);
- Motivation letter from the candidate;
- Recommendations, including recommendation from the EPFL host and the Inria host.
Application must be sent by April 15th, 2017 to Anne-Marie Kermarrec and Willy Zwaenepoel with cc to Julie Pomponne.
