Post-Doctoral Fellowship Opportunity 2020
chercheuse-post-doc_vignetteIn 2020 Inria offers 1 Post-Doc fellowship in the framework of EPFL-Inria International Lab. Deadline for application is July 12th, 2020.
Candidates interested in the projects currently supported are welcome to submit their application to a post-doctoral fellowship. Candidates are strongly encouraged to get in touch with the PIs of these projects, either at EPFL, or at Inria.
Applications will include the summary sheet (to be downloaded here) and the following documents:
• Motivation letter from the candidate
• Detailed CV with a list of publications and highlight the two most significant ones
• Research program, work plan and planned visits during the postdoc, the planned duration of the post-doc (between 12 and 24 months) and the desired starting date (default start date is November 1st, 2020)
• Recommendations, including recommendation from the host Inria research team and the host partner
Application must be sent by July 12th, 2020 to Julie Pomponne
